Are you asking about two phase?Can someone post graphics of the combos? And why not just use 3 wires rather then 5?
... there is no difference how many phases are used. ...
Six-phase is frequently used when DC power is required. It provides better-quality DC (less ripple) with less or no filtering.
I am so interested in four Phase system, anyone can provide some info to me? if you have any idea abt four phase system,
3 vs. 5... each has its own merits.
If you have two hots and a neutral (definitely a neutral under NEC definition) the neutral current will be 1.414 times the current in each hot. So it must be oversized.Thanks! A looks a bit redundant, can't you just combine two wires for a partial neutral? (partial in that its not perfect cancelling)
If you are talking about a 3-wire system, the common, though denoted as a neutral in the diagram I posted, under the current NEC definition I do not agree. A wire can only be a neutral conductor when connected to the system neutral point... and the common junction does not meet the criteria for such.If you have two hots and a neutral (definitely a neutral under NEC definition) the neutral current will be 1.414 times the current in each hot. So it must be oversized.
The voltage to all of the rest of the circuit conductors is the same. So it is a neutral. It does not say that there have to be enough conductors to make the phase circle complete. JMO.If you are talking about a 3-wire system, the common, though denoted as a neutral in the diagram I posted, under the current NEC definition I do not agree. A wire can only be a neutral conductor when connected to the system neutral point... and the common junction does not meet the criteria for such.
What you are describing works for MWBC... but not neutral anything.The voltage to all of the rest of the circuit conductors is the same. So it is a neutral. It does not say that there have to be enough conductors to make the phase circle complete. JMO.
Branch Circuit, Multiwire. A branch circuit that consists
of two or more ungrounded conductors that have a voltage
between them, and a grounded conductor that has equal
voltage between it and each ungrounded conductor of the
circuit and that is connected to the neutral or grounded
conductor of the system.
Neutral Conductor. The conductor connected to the neutral
point of a system that is intended to carry current under
normal conditions.
Neutral Point. The common point on a wye-connection in a
polyphase system or midpoint on a single-phase, 3-wire system,
or midpoint of a single-phase portion of a 3-phase delta
system, or a midpoint of a 3-wire, direct-current system.
Informational Note: At the neutral point of the system, thevectorial sum of the nominal voltages from all other phaseswithin the system that utilize the neutral, with respect to theneutral point, is zero potential.
