Where in the NEC does it state that I have to install the conductors to a three phase range in conduit?
raider1 said:Nowhere, you just have to use a Chapter three wiring method.
Chris
mark henderson said:Chris that is pretty vague. Dont you think? So would 300.3b apply? They dont make three phase romex so you are limited to mc or pipe.
ronnie said:Can I buy a 3 phase assemblied romex with 3 ungrounded conductors,one grounded conductor and one equipment ground?
I looked at 300.3b3 and 300.20b so am I wrong in thinkig you can parrell this run in a non-metalic cable?
winnie said:Four conductor (plus ground) nonmetallic cable is certainly available. It may be difficult to find in common distribution, may be very expensive, or there may be other reasons why this is not a _practical_ wiring method to use.
http://appprod.southwire.com/ProductCatalog/XTEInterfaceServlet?contentKey=prodcatsheet6
-Jon
goldstar said:I can't remember ever seeing a residential 3 phase service (at least not in my area).
goldstar said:I can't remember ever seeing a residential 3 phase service (at least not in my area). Are there any POCO's throughout the US that do this or is it just me not seeing outside the box ?
goldstar said:Celtic,
I can understand a POCO bringing a large 3-phase service into a housing complex but each condo/apt doesn't get a 3-phase panel do they ? Also, is the voltage 120/208 or 120/240 ?
Phil
