So I have been searching the fourm and have seen this in a couple of thread's and trying to make sense of this. When installing single phase loads [L-L] across three phase circuits [L-L-L] how do you calcualte the voltage drop at each load? For example [this seems to be the most common applicatoin] when installing exterior lighitng that is either 480V L-L or 208V L-L, it seems to be common practice to install a three pole breaker and balance the loads [fixtures] across all three phases [AB, BC, AC, repeat] by doing this the voltage drop is calcualted as a three phase VD calcualtion due to having two multiple return paths to the source. My questoin is how would you calcuate the voltage at each location where your loads are connected L-L and not L-L-L? Would this create an imbalacend load for this portion of the cirucit untill the next load or two away where it would become balanced again?
