electrofelon
- Cherry Valley NY, Seattle, WA
I feel like I must be missing something real obvious. For simplicity, let's say the load is balanced. W=VxIx1.732 doesn't match what you get with the method in the photo??
Can someone take a stab at explaining this? I get that you only need two CT's for a delta, but what I dont get is the W=W1+W2.....
the power across each coil is V x I/sqrt3
3 coils = 3 x V x I/sqrt3 = sqrt3 x V x I
at peak the power in one coil = 0, so adding any 2 legs gives the total
This is simply known as the Two Wattmeter Method and is illustrated perfectly on many websites. So, rather than copy and paste someone's work, you can Google for yourself.
