I did a load calculation for a addition to a existing building that I thought was a single phase service. Historical data shows 25 kw of load. My load calculation for the new building was 29 Kw So my new load would be roughly 251 amps. It turns out my service is actually three phase. Any help on determining my new three phase load?
My other question is the 3 phase service is 120/240 with a high leg. I talked with the POCO and he does not believe they will want to change this as there are multiple building fed off this bank of transformers. I would like to install a 320 class 3 phase meter socket to feed existing three phase panel and then use Phase A and B in meter socket to feed a new single phase panel next to three phase panel? Phase C in existing panel is pretty much useless so to me it would be cleaner if I could just install the new single phase panel. There is not a 200 amp single phase meter to be found from my supplier. Any guidance would be greatly appreciated. Thanks
