Electric-Light
Suppose a building receives power at 208Y/120v
If everything was perfectly symmetric, then you'd have 120v L to N, and 207.8v L to L, but lets say it isn't.
A dorm room receives a neutral, A and B.
Currently, there is a microwave running from an outlet fed from A. There is nothing connected to an outlet fed from B.
N to A is 118v
N to B is 123v
I know I can measure A to B, but if I wanted to can I calculate voltage between A and B from the above and the fact they're shifted 120deg from eachother?
Also, would a load between N and C in the room next door affect my calculation?
Something that gave me a pretty close answer is average of the above, (118+123)/2 = 120.5*sqrt(3) = 208.7v. The value looks reasonable, but I'm not certain if I'm using the right formula.
N to A is 118v
N to B is 123v
