This applies to a single family dwelling:
1)If an electrician (someone elses job) installs a 20A 120V circuit to a kitchen disposal (reguardless of the reason,) should he install a 15A or 20A switch above the sink?
2)Installing a 100A 1PH 120/240V panel in detached garage fed from the main 200A panel located in the basement of the house. Is a means of disconnect with or w/o OC protection required in the garage for that panel or will the 100A breaker in the house's panel be suffice?
3)Thoughts on feeding outside receptacles...
Feed from the garage GFI's if distance is not too far to be cost ineffective, feed from adjacent (closest) receptacles inside the house and install GFI's outside, or run a seperate circuit for all receptacles w/one passive GFI at the front end? Do they need to be 20A? For simplification, lets consider we're dealing with 3 to 4 outside receptacles.
Thanks to all that respond...
