three way neutral switching invalid url!
wyreman
SF CA USA
electrical contractor
There's a thing here called a Chinese three way which involves andalusite neutral that needs a break before make. I never understood it. The switch is stuck in one position. IlL ring it out and them crack it open and let you know
wyreman
SF CA USA
iPhone autocorrect should read "a switched neutral"
480sparky
Iowegia
I'd say two of the terminals are tied together... one for power in and feeding the switched load, and the other for power out to feed something else.
A version of this:
wyreman
SF CA USA
My singlE screw is brass tho compared to the other two silvery terminals. I'll try and ring it out Tom. Since the $ won't throw, I'll prob put it on a bandsaw
readydave8
re member
Clarkesville, Georgia
electrician
That's hilarious, I really did laugh out loud. I wondered all day if andalusite was a semi-conductor and had something to do with why the 3/way had an off. Am I the only one that didn't know about the phone autocorrect of which you speak? Did everyone else know what the sentence was supposed to say?
wyreman
SF CA USA
three way switch indeed
hey i looked it up
the patent number that is and here is the poop
looks like it is a kind of three way but i can't figure it out tonight
already snapped off the switch and the springs popped out...
wyreman
SF CA USA
to be more clear it looks like a double pole double throw switch that can be modified to perform some kind of $3 function.
And I think that was how they used to do some kind of make before break neutral switching in the old victorians...
this may have been a modern [1954] version of the dated [1903] switch
think laurel and hardy meet the three stooges...
