Three Way Switches Amp Question for Residential
Otterbox
Alabama
I have two three way switches on a 20 amp circuit. One switch is a 15 amp switch and the other is 20 amp switch. What is the residential code for this situation?
Thanks
You almost never see a 20 amp switch used for residential. But it never hurts to check the load.
If you were to install a dimmer the odds are it would only be 600 watts ( depending on load).
