K8MHZ
- Electrician
Isn't this an interesting breaker combination?
The 25 amp breakers that have the handle ties are for the water heater. And they actually worked!
I went out to see what was initially considered to be nuisance tripping of the 25 A breakers. I found a thermostat and lower heating element completely soaked with water and evidence of sparking across the terminals of the lower element. Also everything was rusted to the point of it likely being impossible to work with.
I condemned the heater. I also showed the HO the char marks on the plastic cover and one of the brass terminals, along with a much larger char mark on the styrofoam insulation.
But in all my years, I have never seen breakers set up that way. It's unusual enough to see 2 pole breakers with different ratings, but to see two of them paired up like that is a new one on me.
Just to be clear, I know the breakers had nothing to do with the problem, I just thought they were unique enough to get a pic of.
