I quoted a labor only figure to wire new kilns at a sawmill. I am reasonably sure that the owner is going to try to use his 'own forces' to do the work.
The plans are to wire the fans in the kiln with #12 thwn. The ambient operating temperature of the kilns will be in the 160-180f degree range.
Can thwn be used for this application?
If no, then what will happen if they do? Will the insulation break down in a fairly short period of time, leading to multple failures? (there are a total of 32 fans, all of which operate in within this temperature environment.
