We have an industrial facility with two service points. There is a "tie switch" between services "A" and "B". The system is "kirk-key" controlled to prevent the tie from being closed with both services energized. Knowing the ingenuity of maintenace personnel, the "what if" question arose.
Both of the plant service transformers are fed by the same primary
line and both are phased alike, however, the impedeance is different.
In the highly unlikely event that this tie switch was ever closed with both services energized, what would be the result ?
