I have a hot water recirculation pump (fractional HP, 120VAC) in a residence that is controlled by an aquastat. I want to put a Time Clock on it so it doesn't run late at night. In looking at the Intermatic ST01C, it seems from the instructions that the TC switch leg needs to be connected to the load all the time, and can't be interrupted by the aquastat contact. Is this correct?
I was going to do the same for some photocell controlled lighting. If these won't work, guess I'm stuck with the more expensive Time Switches that have "real" contacts?
