Hello all,
I have question on time current coordination (TCC) done in software's available. I keep on having discussions with people on this. Is it correct to show coordination of a 3 pole breaker with a single pole breaker on TCC in a 3 -phase system? For example a panelboard has a main of 225A and the branch breakers are all single pole 20A. On the TCC will the trip curves showing coordination between 225A/3P and 20A/1P be correct?
I think the three pole breaker trips all three poles for an overcurrent on a single phase, it does not require all three phases to have an overcurrent. Therefore, if there is a fault downstream of one of the single-pole breakers, one phase of the three-pole breaker will also see this same current and could trip if not coordinated properly.
People usually confuse the phase domain with sequence domain and I get mix comments on it. I really would like to know if it is correct to show 3 pole breaker and single pole breaker on a TCC are correct? If correct how to explain this to people who dont agree. If not correct. Why?
