T
T.M.Haja Sahib
Guest
Is timer switch better for street light application than photo sensor switch, as the latter is more liable to collect dust and malfunction? Thanks.
Just how much dust are you talking about? If it ever rains it should wash it off.Is timer switch better for street light application than photo sensor switch, as the latter is more liable to collect dust and malfunction? Thanks.
To what extend does the "time is gets dark" or "the time it gets light" vary from day to day, in your area of the world? In my area, there is a least a four hour difference from mid summer to mid winter, in the time of day that I would want the street lights to turn on. So in this area, a timer would be ineffective at controlling street lights.
Not true of all "timers". Some timers have an astronomic feature (dusk/dawn timing), and some are battery operated or have battery backup.If you have a power interuption, all the timers would probably need to be reset. Not so with the photo sensor.
In most locations no, if near some facility that creates a lot of dust maybe it is worth consideration, but the photo cell in question would need to be pretty close to the source of some pretty extreme dusty conditions I would think.Thanks for your replies, guys. But I just wanted to have the confirmation or not whether the dust collection is the problem with the photo sensor switch for street light applications.
It gets pretty bad at or near a cement works.In most locations no, if near some facility that creates a lot of dust maybe it is worth consideration, but the photo cell in question would need to be pretty close to the source of some pretty extreme dusty conditions I would think.
Careful selection of placement of photocell becomes necessary. Careful placement of luminaires is also needed. If luminaires get covered in dust they may not provide enough illumination.It gets pretty bad at or near a cement works.
I think it is better to do away with photocell by using timer switch in street light application, where dust accumulation can not be avoided.Careful selection of placement of photocell becomes necessary.
