ceb58
- Raeford, NC
I need help deciding on an install. Here is the situation. I am doing a fellowship hall for a church. At rough in I knew they were planing on installing a 120v LED back lit cross on the end of the building. I roughed in a wp box on the out side for a photo cell to control the cross and took the switch leg,2 wire/g, into the unfinished storage area above. Now at the last of the trim out they now want it on a timer also. They are adamant they do not want the timer out side next to the wp box with the photo cell. What I am thinking about is picking up power from the recp. at the air handlers set a box with a switch (as a disconnect) to feed the clock motor only. Then set another box with a switch (disco) for the leg coming from the photo cell and send it to one side of the contacts in the timer with the other leg going to the cross. That way I can set the timer to come on at say 4:00pm but the photo cell will hold it off until dark and then turn it off at around 10:00pm. Any problems with the two power sources in the timer?
