Coppersmith
- Tampa, FL, USA
- Electrical Contractor
I saw a news story about clusters of tiny houses (94 sq ft). The individual units had no kitchen or bathroom. There is a common kitchen and bathroom building. These are in Colorado and are used to house the homeless. It got me thinking about how I would wire such a place.
Each of the individual tiny houses had interior receptacles and built-in lighting, a porch light, and an external receptacle. I saw a window a/c unit. They are in a cold climate so I’m going to assume they either have heaters in the a/c units or separate space heaters. One resident said he had a fridge. (I assume a dorm sized one.)
Cost was a major factor, so what is the least costly way to wire these units? Here is what I thought. Each unit has two 20 amp circuits. One dedicated circuit for the a/c and heat and one circuit for everything else. These circuits terminate in a two slot interior panel. The panel is fed with 120v (not 240v) so the two split phase sides are jumpered. Having a panel on each unit allows the residents to control their own breakers in case of overload. Conduit runs from the panel to under the unit crawl space and into a junction box. This is where the feeder would be attached.
One or more central common meters feed main distribution panels with a one pole 40 amp breaker* for each housing unit. Underground feeders feed each unit. Since it’s a 120v feed, only one hot wire is required (a cost savings in wire and conduit). The main distribution panel can be locked to avoid residents turning off a neighbor’s power. The residents pay rent. Due to the nature of the place, I’m assuming the organization running the place would provide the electricity as part of rent.
A common 200 amp service could handle 5 or 6 units. A common 320 amp service (with two 200 amp panels) could handle 8 to 10. The largest cluster I read about was 14 units plus the common building.
* I saw a post a week or so back about single pole 40, 50, and 60 amp breakers being available and what you would use one for. Here is an example.
