tld38
tld38
Cleveland
I noticed that the 2X4 fixtures we are installing have a plug disconnect at the fixture. So that if you are daisy chaining you can isolate that fixture without affecting others. Is this a requirement as of 2008 NEC? Thanks much!tld38
Welcome to the Forum. What type of plug? What type of wiring method? i.e. MC ect.
410.130(G) of the 2008 NEC
tld38
Wiring method is mc cable. I should have been more specific, It is a quick disconnect fitting inside the access plate in every fixture, an actual stablock device that you connect your hot & neutral too.
It's a quick-connect to mate to the building's wiring system. Unfortunately, you probably didn't wire for it, so you got the wrong fixtures.
No, I don't get that at all, it's just the newly required ballast disconnect
Of course. If your using the 05 it's 410.73(G). Started to be enforced 1/1/08.
I misread it. You're correct. I was thinking the quick connect was on the MC.
Either that, or the fixtures has Wagos pre-installed.
