Replacing an old fussed sub panel, fed from a 200 amp disconnect, fed from a larger service. This is a 240v. three phase corner grounded delta. The panel being installed is a two bus using the N for the grounded B phase. Should the N bus be bonded or would it just be redundant. The entire system is metal.
