A Generator with system bond installed with 400 amp OCD suppling a latrine unit. The service conductors are parallel two 3 conductor 4/0 with #4 ground, to a 400 amp panel, 250.122(F) states a #2 EGC is needed. Can the neutral conductor be used as the path by either installing a system bond jumper at downsream panel, with out removing bond in generator.
