A Customer needed to replace the 17 years old Siemens 200 amps service panel for a Solar Ready Panel. The old panel was partially labeled and the multiwire on single pole breakers and not ties.
I recommended that at the same time of the replacement to install double poles for the multiwire, group the multiwire (neutral & ungrounds) inside the panel, make the full directory of the circuits and because there was a lot of space as this is a large panel, to leave space between the large appliances breakers to disipate heat as this panel is most of the time under the Arizona heat and facing the sun most of the day, and torque to specification all electrical connections (breakers, neutrals, etc.)
A contractor sent a non-licensed electrician to do the job and replaced the panel in the same condition it was, partially labeled, single pole breakers with not ties for the multiwire, etc, etc., and he stated that it didn't need ll that jumbo-mumbo because it wasn't an upgrade.
Your opinions please?
