To UL or not to UL. That is one of the questons.
jerrysounds
San Diego
Here's the story, I go to a call on Saturday where the lights go dim when you turn on any appliance in the house, 240 or 120volt. So I go out to the service panel and take a look at the connections on the house side. Everything is good. I pull the cover off of service side of the panel and find the neutral is discolored. I then turn off the main, then check to see if the neutral is loose. The neutral lug falls off the neutral bar in my hand with very little effort !! I tell the HO that he needs a new panel. I temp the neutral line to the load side neutral bar to give the HO power till Monday when I can make the change.(I'm a nice but stupid Guy I Guess). Monday morning I get a call from HO, He wants me to wait for the insurance adjuster to take a look at the panel in its currant condition so he may make an accurate estimate. Fine, I wait. The next day the HO calls me and says he is canceling the contract. The Insurance adjuster (from something Farm) insists that the panel is still usable. Apparently he came with his own electrician and a SDGE (power company) crew. They told the HO that they will install a new lug on the burnt neutral bar and the panel will be as good as new. They also told the HO that this will NOT need a City inspection!! Here's the question? 1) Doesn't the new lug need to be inspected by a UL certified engineer, an engineer or at the very least a city inspector? In NEC 110.12 it says we are not to use any part that is damaged or burnt. 2) The power company (SDGE) can make repairs to there equipment but can they make repairs to the HOs equipment and can they do it without inspections? 3) If the neutral bar is not sufficiently burnt to be replaced how damaged dose it have to be before we as electricians can tell our costumers that we have to replace the parts. I am a little mad about this, not only did the power company and the insurance company take money out of my pocket but they are making it seem like we were out to take advantage of the HO. These guys are not very familiar with the NEC or the NFPA (which also say that you must replace any parts that are damaged in any way). What do you say???? Thanks Jerry
:mad:
