tombstone melting and smoking
i was called to look at a group of lights in a gyms locker room where the tombstones were causing members to be concerned from seeing smoke come from above the locker where they lay facing upwards < they say that they install the bulbs correctly an even double check to make sure but for some reason it still has be happening there is about 100 light fixtures total, with about five connected above each locker. anyone know what may be causing the tombstones to melt?
Smart $
Esteemed Member
Ohio
aaron goff said:
...anyone know what may be causing the tombstones to melt?
I only know of one cause...arcing from contact to lamp pin (or vice-versa).
Minuteman
Where all the ballast changed recently for the incorrect voltage? Maybe the panel is 240V Delta and someone move the breaker to the high leg? :confused:
Never overlook the obvious.
celtic
NJ
georgestolz said:
Just to be sure I'm up to speed: A tombstone, as referred to in this thread, is the socket the fluorescent plugs into, right?
Well it ain't pizza:
Some possible flavors of the tombstone in question:
catchtwentytwo
Is the humidity very high in the locker room? Are there signs of moisture in the fixtures?
TommyC
Westchester, NY
celtic said:
Could you imagine having to work with me?
Yes I could, I can imagine trying to get the work done through the laughter. It actually sounds like me working with my helper. I love sending him to the truck for the 2" pipe stretcher and watching through the window as he hunts for stuff like that.:grin:
