Alwayslearningelec
- NJ
- Estimator
What is the mainstream brand that most electricians use for tool. I have to buy pliers(three types), screw driver, hammer etc.
Any good place to buy my Klien tools at a good price?
Thanks.
Thanks.
I can't tell you the last time I used a regular phillip's head screwdriver for anything.
They still make those?:-?
I'm going on record saying that lenox folding saw was a total piece of junk for as long as I had it. Cutting in wall boxes at time the blade would open up plus it was always loose. I got the Ideal straight handle jab saw and it is working much better for me. It was cheaper too.
I've had the same one for years, never really had a problem with it. I dropped it and broke it once, and bolted it back together, still works. Different strokes for different folks, I guess.
I also would recommend the Lenox saw holder. It's great to have one holder that you can swap between wood and metal blades. Don't forget a tape measure and a pencil Showing up without them will put you high on the dummy list. These are a few of the tools in my pouch that I think fit the bare minimum:
Screwdriver set:
http://chadstoolbox.com/index.asp?PageAction=VIEWPROD&ProdID=278
Linemans: (if you don't like this style there are plenty others to choose from)
http://chadstoolbox.com/index.asp?PageAction=VIEWPROD&ProdID=364
Dikes:
http://chadstoolbox.com/index.asp?PageAction=VIEWPROD&ProdID=616
And probably the best adjustable wrench I've used:
http://chadstoolbox.com/index.asp?PageAction=VIEWPROD&ProdID=348
Don't skimp on tools. They are the extension of your hands, and your safety relies on them. Buy the best you can afford.
If you do need a cordless drill, I'd recommend getting the hammer version of either a Milwaukee 18V (new generation Li-Ion that takes the larger 18V batteries, just coming out now) or the Metabo 18V Li-Ion. They both have massive torque for drilling through wood and short bodies which make it easier to get the drill in tight spaces. I've also heard good things about the Makita drills.
One other thought: When looking at hammers, I think "electrician's" hammers with the straight claw are nice. Try to find one that has approx. 14"-15" overall length as you can use it for setting wallcases during rough in.
I was instructed from my start in the trade to memorize where my tools are in my pouch, so I don't have to look down to use them.The problem I have noticed with having all the tools from the same manufacturer is they all look alike. With 6 screwdrivers in your pouch, you pull out 5 just to find the one you need.
