TORQUE MOTORS
tregarsa
I'm confused for torque motors if the rates current shall be locked-rotor current is the same as the current nameplate mentioned in sections 430.6 (B), 430.32 (A) (1), 430.52 (D), 430.83 (D) and 430 110 (B). Please give me an illustrative application of each section above to select: 1) The ampacity of branch circuit conductors. 2) The size in amps of motor overload protection. 3) The size in amps for the protection of motor branch circuit short circuit and ground fault 4) The size in amps of the disconnecting means, and 5) The size of the motor controller in amperes.
Thank you very much. Saul Trevino.
