Torque screwdriver
Sierrasparky
USA
Electrician ,contractor
Which torque screwdriver would you recommend for small screws terminals like 12-20 amp breakers and neutral/ ground terminals. Mine just disappeared ( hope it's temporary ) and it was probably due for a calibration anyways and I really need a second one.
ActionDave
Chief Moderator
Durango, CO, 10 h 20 min from the winged horses.
Licensed Electrician
I have only used two kinds- Klein and Snap On. Of the two I much prefer the Snap On. It has a more comfortable grip and is easier to set the torque value.
Hot tip. The company that makes the Snap On screwdrivers sells them under their own name for less. Trouble is I can't remember the name.
Ponchik
CA
Electronologist
I have the Wiha 28508 20-70 inLB.
It is pretty good so far. It has good chubby handle so gives you good leverage.
