mark32
- Currently in NJ
Hello, I was just wondering how many out there use a torque wrench and/or torque screwdriver on their terminations.
JohnME said:Never use one, problably should, everyone laughs when I say "wheres the torque wrench?" We go as tight as possible, without breaking anything of course- havn't broken any gear yet.
dduffee260 said:We have set several MCC's. The buss requires a torque of 35lbs I think. It does not feel like much but Square D insist that we torque to that spec. Most of the time with other smaller gear though I am like all the other guys. Tighten it till it feels good.
celtic said:What would 110.3(A) & (B) say about "We go as tight as possible" or "Tighten it till it feels good"?
Not to mention 110.14. FWIW, the '05 NEC Handbook includes 4 "Commentary Tables" giving torque values for slotted, hex, allen & lug bolts.celtic said:What would 110.3(A) & (B) say about "We go as tight as possible" or "Tighten it till it feels good"?
Do you think the inspector will appreciate your sarcasm?dduffee260 said:Ok, here is what we do to remedy this. I will start using a torque screwdriver and torque wrench on all my required connections. When I call for an inspection, I am requesting that the inspector also go behind me and check all the torque settings on the connections that I have torqued.
dduffee260 said:110.3(A) & (B) wants us to torque all the screws on the breakers, connections, devices, etc. How many people on this board actually own a torque screwdriver and use it on every breaker connection? Out of the several thousand if not tens of thousand breakers I have terminated I have had very few problems. I have had a few, but we live in the real world where time along with safety is of the essence on a project.
brian john said:So duffe what you are saying, is your quality of work is questionable and the inspector needs to check every thing you install, because you have an issue with a requirement?QUOTE]
John, what is an inspector for? They are there because there is a question about everyone's quality of work.
