Kdog76
- The Dairyland State
I would like some guidance as to picking out a decent torque wrench. I have seen some different models, and I do see the beam style is a less expensive tool then some of the other ratcheting styles. Would be used primarily for torquing AL connections on meter sockets.
Also, I see some differences in measuring torque (Ft/lbs or In. / Lbs). My meter sockets (Main lugs - hex head) say to torque at 250 in. lbs. If I get the Ft.Lb model do I need to know the conversion from Ft/Lbs to In./Lbs.?
The one I saw at the local sears was a 3/8 ratchet that maxed out at 250 in.lbs. Too small? Any suggestions?
