aelectricalman
- KY
If I am trying to monitor the total harmonic distortion of a system (12.47kV) but I am not able to measure at the meter point (due to external factors), can I measure the sum of its parts and at a stepped down voltage (480V)? Also, can the Vthd and Ithd be measured accurately by summation of all the parts, given whatever factor needed to be considered for the ratios of the transformers? The example is that I have 4 services that are 480V. I want to place capacitors on the primary 12.47kV but have no access to measure the 12.47kV, just the 480V. Since there are 4 services each with 4 pole mounted step down transformer, I will have to measure at each of the 4 gear. My understanding is that the transformers will filter a lot the harmonics. I dont know the ratios but any help or direction would be appreciated.
