Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
If a 300 KVA delta delta 3 phase transformer 4800 volts primary to 480 volts secondary and the math (KVA / secondary voltage x 1.732) yields about 361 amperes then is this the current between phase legs such as A to B, B to C, A to C?
If so it would seem Phase B TO C and A to C would also put out 361 amperes? And therefore total amperes exceeds 360? (Secondary only seeing 360 wouldn’t make sense if true)
I just want to make sure I told my boss correctly that output is 360 amperes total before he upsizes to a larger 600KVA transformer.
Thanks
Thanks
