I'm bidding for a small project. It's just one 5.5 kW (about 7.5 HP) VSD running at a maximim of 4.6kW plus a few controls in a box.
The box has to be totally enclosed non-ventilated.
IP65 for UK and Europe. Probably NEMA 3X or higher.
And it has to be stainless steel.
Total losses will be around 150W all of which will have to be dissipated through the walls of the enclosure.
I'd like to limit the temperature rise inside the box to no more that about 10degC (18degF)
Box dimensions will be dictated by required surface area to dissipate the heat rather than by the components it needs to house.
If the box was mild steel with two part epoxy coating, typical for most standard enclosures, I've been there and done that. But stainless?
My question is what surface area does my stainless steel box need to have?
Any information, Imperial or metric would be appreciated.
