busman
- Northern Virginia
- Master Electrician / Electrical Engineer
I need to connect a tow-behind leased generator to a temporary shelter for research purposes.  It is 208/120Y.  I could not get 5-conductor Type W cable quickly enough.  I have 4-conductor.  Any Code issues with the three hots and the neutral in the 4-conductor cable and a separate properly sized EGC run separately?  I would strap the two together.  It "feels" OK since these temporary installs are frequently done with a bunch of single conductor cables.  I will post signage indicating that the EGC must be "first connect / last disconnect".  Thoughts?
As always, thanks. Got this one on a short fuse and don't have days to spend trolling the NEC for answers.
Mark
Mark
