A small town park band stand with a steel structure.
There will be a panelboard mounted on a rack near the band stand. It will serve a couple receptacles and lights in the bandstand. The panelboard is fed from a park building about 100 feet away.
Should the band stand steel be bonded to the electric ground in any way.
Follow up question: If the panelboard is mounted on steel (kindorf) (as opposed to a wood rack) should the steel be bonded (it would be via the connection to the panelboard enclosure)?
