I am a bit confused by a townhouse project I am looking at. Each of the 20 townhouses is fed from a meterstack on a common wall. There are breakers for each townhouse on the meter stack. The townhouses are built over a common area of underground parking where the individual feeders will be ran. Since they are classified as townhouses, not multifamily dwellings, does each townhouse’s individual panel require a main panel disconnect as required by 225.32 or is the meter stack sufficient. I have never seen townhouses with a common garage beneath and have always thought of townhouses as a separate structure.
