P pdl Member May 3, 2007 #1 i am trying to find if there is an artical in the nec pertaining to the insulation rating on tracer wire for direct burial polly gas line
cowboyjwc Moderator Staff member Location Simi Valley, CA May 3, 2007 #2 Not in the NEC. You might try looking in the UPC or the IPC depending on which one you use.
N NoVA Comms Power Senior Member Location Alexandria, VA May 3, 2007 #3 You might also try the National Fuel Gas Code (NFPA 54). Last edited: May 3, 2007
