Learning Always
- Mn
- Maintenance electrician / Pt licensed contractor
How accurately can you guys tone and follow wires throughout a typical residential setting? Can you follow a wire and tell exactly where a buried jbox or splice has gone bad, drill a hole and be spot on? I use a fluke pro 3000 hook it up to the neutral and hot and I can tell what openings are on the circuit and roughly follow the path of the wire behind drywall but with very low confidence. Just curious how accurately others can trace wires out and what they are using.
