hbendillo
- South carolina
I am have a problem circuiting track lighting for a restaurant for which I am the engineer designing the circuiting. The problem is with respect to the energy code limitations. I know there are current limiters that can be installed in tracks to limit load but we have so many sections of track that even the current limiters don't help me even if I put a 1 amp current limiter on each section of track. I am working off a prototype for this particular restaurant chain so they laid out the track, not me. And it is all pendant mounted track. My question: Can I install a current limiter on one section of track that feeds a separate section track? If I daisy chain some of the track sections so that the current is limited on those sections, it would decrease the calculated energy load quite a bit.
Other suggestions would be appreciated. I tried connecting as many sections of track as possible to a single circuit breaker. I tried specifying 15 amp instead of 20 amp circuit breakers in the panel. Are there 10 amp circuit breakers available for a commercial grade panel?
