Related to track lighting where the track is mounted over top of a flush mounted j-box w/mud ring, the track pigtail gets spliced to the conductors in the box then snapped onto the track that is installed over the j-box, then the plastic cover screws on.
How the heck are you supposed to access the wire nuts (for troubleshooting, etc) once the track is mounted over top of j-box?!!
I was troubleshooting some track lighting today that had the LED bulbs periodically flashing. I was attempting to follow the circuit around looking for a loose neutral.
(6) 8 foot tracks with line voltage LED MR16 style lamps. Tracks switched in 2 groups of 3, with LED dimmer on each set (and set up for 3-way).
The circuit is set up as a multi-wire with 2-pole breaker.
Each circuit (3 tracks) would randomly flash for ~60 seconds, the other set of tracks (other circuit) would not be flashing at the same time.
My assumption is either a loose neutral or an issue with the dimmers (both in same box)?
My main frustration was accessing the wires in the junction boxes!!
RANT OVER!!
Any input is always welcome!
RANT OVER!!
