Installing track lighting in a ceiling tile grid ceiling, I have two options for the power feed.
One option uses a "power module" where the leads stick out above the ceiling. I cannot figure out how to install a junction box for the wire splices above the ceiling. I don't think I can secure the junction box to the ceiling tile or T-grid. I don't see an easy way to drop a support from the ceiling. I don't think the code allows securing anything to the ceiling grid support wires.
The other option uses a "power module" where a romex cable could be directly wired above the ceiling to the power module so I don't need to worry about a junction box. Is Romex allowed in a commercial building in the suspended ceiling area? If so can it lay on top of the insulation above the ceiling tile? Without a junction box it is difficult to use flexible metalic tubing. If the romex and/or metalic tubing are required to be supported away from the top of the ceiling tile/T-grid, I will have to look more.
Any ideas? Thanks!
Doug
Any ideas? Thanks!
Doug
