Section 220.12(B) addresses track lighting loads.
The volt-ampere (VA) load for 2 ft of track is 150 volt-amperes because a value of 150 VA is more consistent with standard lamp values for 2 ft of track. It should be understood that 220.12(B) is not intended to limit the number of feet of track on a single branch circuit nor is it intended to limit the number of fixtures on an individual track. Rather, 220.12(B) is intended to be used for load calculations of feeders and services.
Example
Suppose a lighting plan shows 62.5 linear ft of single circuit lighting track for a small department store featuring clothing. Because the actual track luminaires are owner supplied, neither the quantity of track luminaires nor the lamp size is specified. What is the minimum calculated load associated with the lighting track that must be added to the service or feeder supplying this store?
Solution
According to 220.12(B), the minimum calculated load to be added to the service or feeder supplying this track light installation is determined as follows:
The minimum load that must be added to the service or feeder is 4800 VA.
It is important to note that the branch circuits supplying this installation are covered in 410.101(B). For the lighting track branch-circuit load, the maximum load on the track cannot exceed the rating of the branch circuit supplying the track. Also, the track must be supplied by a branch circuit having a rating not exceeding the rating of the track. The track length does not enter into the branch-circuit calculation.
