Hi 1st timer here.
I am currently installing a 300amp vacuum mold machine that requires a 480V four wire wye and the building has a 480V four wire wye feeding the building. The problem being is the bus does not supply me with a Neutral and the machine is about 500 feet away from where the service comes into the building from Edison. So I believe my options are 1.Pipe the service from the machine to a 480V Breaker (500ft away) so I can find my neutral there,
or use an isolation transformer 480 to 480. Since the building is fed with 480 / 277volts to ground wye.
Can I use a 480/480 isolation delta to wye transformer here??
If I am missing something Or if there is a better way of doing this please let me know. thanks
