Tranformer Main/Secondary Fuse Sizing.
Digital
Hello all,
I have a question regarding prm/sec fuse sizing. This is for an Extruder application. The primary feed will be 480 vac 3 phase and the secondary will be 240 vac single phase. The way it has been it set up is 2 legs from the 480 will feed 3 separate 7.5 kVA transformers. I can only assume the previous engineer used this setup for load balancing as he is not here anymore.
480 VAC
L1 & L2 ---> Primary of first transformer.
L2 & L3 ---> Primary of second transformer.
L3 & L1 ---> Primary of third transformer.
From the secondary side of the transformers all X2 legs will be tied to ground and a Neutral distribution block. All the X1 legs will be separated fused and terminated at a power distribution block.
The question of the hour is when sizing primary fusing should i size for three phase or single phase?
Thanks in advance.
Digital
you can look at it either way..
you have a fairly balance set up with 15 kva on any two legs or
22.5 kw at 3 phase.
Either way you are looking at about a 30 amp load.
Since you have secondary protection, you can primary protect anywhere from 30 to 40 amps depending on your wire size.
22.5 kw at 3 phase.
Thanks for the speedy reply augie. Ive been coming up with the same numbers. Was not to sure and needed a second opinion.
Thanks again
Digital
The code seems to say that you treat this installation as a 3 phase transformer.
450.3 Overcurrent Protection
Overcurrent protection of transformers shall comply with 450.3(A), (B), or (C). As used in this section, the word transformer shall mean a transformer or polyphase bank of two or more single-phase transformers operating as a unit.
You have polyphase bank of 3 transformers operating as a unit or single transformer.
Don
I had the exact same take as I was reading the OP, when he said "3ph primary and 1ph secondary".
He's actually going to end up with a 416Y/240 secondary system when he joins the X2's.
The neutral should be grounded, too, right? Or is this permitted, but not required?
Is the intent to have 240V L-L, or 240V L-N? Both could be considered single phase. If it is 240 L-N, then the connection as described is going to be consistent with what Larry said about 416Y/240V. With a 480V HV connection, I'd say this is a specialty transformer?????
Sorry about that. There are three separate single phase transformers (480 pri x 240 sec) with one leg on each of secondary 240 side grounded.
