Toros
- Tujunga, CA
Suppose I need 190 A @ 240v, 1phase from 12o/208v, 3ph service. I use 45 kva xfrmer with primary opcd , @ 100A-3p What if i use 45 kva xfrmer with opcd , @ 60A quest.: Would I get the same output as if I used 100A-3p opcd at primary side . I am minimizing current input to the tranformer ??? I will tell you the rest, the confusion behind it after you replied .... Thank you
