A/A Fuel GTX
- WI & AZ
- Electrician
I have a Pedestal service point with an automatic transfer switch about 6' away. The neutrals are not switched and are all terminated together in the switch. Since this transfer switch is service rated with a main breaker and mounted remotely from the service, is a grounding electrode system required? I'm thinking yes because the transfer switch is viewed as a separate structure. As a side note, does the generator need a ground rod? I think I remember seeing a video from Mike stating that it was not necessary.
