Hey guys,
ie
Need your help. I've started a new job installing residential 8kw Generac Generators. I've never done generator installations before last week. I live in Mass. My question is about the actual transfer switch. Specifically the neutrals only. Those guys that install transfer switches understand that the neutrals are labeled 1-12 on a 12 circuit panel. Can I remove the neutrals from the transfer switch and just tie in the main neutral from the transfer switch to the main neutral bar in the main panel? So I would eliminate the 12 neutrals from the transfer switch and tie the main neutral only. The only reason I am asking is because it would keep the main panel extremely clean. I do want to follow the code.
Thanks guys!
Mike
ie
Thanks guys!
Mike
