Does a service rated automatic transfer switch used in conjunction with a stand by generator have to have an amperage rating equal to or in excess of the meter base? I need to use a 320A meter base in order to get the double lugs that I need to supply both the house panel and an out building panel.The outbuilding will feed off the load side of the meter on a separate set of lugs(does not require standby power) and the ATS will feed off the load side on it's own set of lugs. My total load will most likely never exceed 150A (house and building combined) but cannot use a 200A socket because of the lug arrangement. I am being told by the generator supplier that both units (meter and switch) have to have compatible amperage ratings, I disagree.  Any input appreciated.
