puckman
- ridgewood, n.j.
There is this generator that supplys back up power up to 2000amps in a power failure . Now during online test the gen starts like it should when it sees a loss of power during testing. When it sees utility power is restored the MCC main trys to close ,the main is controled by a plc . You can here the motor winding in the main breaker bucket trying to close and then opens again repeating this over and over again.. It also has a manual handle that charges the breaker, which we did at different times. The breaker for some reason always says spring discharged and some of the other cb in the switchgear are saying the same thing.
There is a transfer switch that someone played with that has a keyed switch " auto close" "auto open" " manual close" and maybe one more setting.
We are not sure where it should be. Any ideas where this switch should be set?
We turn off the gen and than have to close the main by a chicken switch . Thanks for your help.
