Multiple questions, so I will number them so everyone can refer to the numbers.
First, does everyone agree with this:
(1) If one uses a three pole transfer switch (3P), the only Neutral to Ground bond (NGB) is at the normal source transformer secondary (which I will call XFMR-norm). The neutral is not bonded to the ground in the generator. Correct?
Next:
(2) If we have a 4 pole switch that switches the neutral (4P), then a NGB is placed at the XFMR-norm, and a NGB is placed at the generator. Correct?
Here is where it starts to get tricky:
(3) If there is an existing 3P transfer switch, can a 4P switch be added to the same generator? (I'm thinking in emergency mode, the 4P switch would get its NGB from the utility transformer through the 3P switch.)
(4) The generator feeds a transformer, that feeds the transfer switch. (So there is a transformer on the normal side and one on the emergency side.) Does one have to use a 4P switch with NGB at both transformers? Or can you use a 3P switch and only bond at the XFMR-norm?
(5) If a generator has two transfer switches, and it each one is connected to a different utility transformer, do all the transfer switches have to be 4P?
Thanks in advance:
Steve
Next:
Thanks in advance:
Steve
