erikredd_13
New member
How do you ground a load center to a transfer switch? My utility secondary will run through the utility meter to a manual transfer switch. This is where I will be able to hook up a portable generator or run utility power to my load center.
Do you isolate the neutral and ground to prevent current from running through the ground? Does this work, in a sense, like subfeeding a load center from another load center?
OR
Do you bond your neutral to your ground at your load center?
OR
