Pflat
- California
- Greenhouse horticulturist
Have a Project we are sourcing a transformer for.
We have a 208/120v 200amp 3phase panel to work from for primary.
We are trying to run 15 dehumidifier appliances that are 277v and draw 9amps each. Dehums will start at most 3 at same time, but will often all be running at same time. All 15 appliances on their own circuits, so 5 per phase equally balanced.
Electrician suggested a 480/277 panel (that we have already on site available to use) for secondary distribution to the dehumidifier appliance circuits, and a transformer between the 208/120 feed panel (primary) and the 480panel (secondary).. panel and transformer will only ever be used for these dehumidifier appliances, no other equipment will be added.
Can you recommend a transformer for this application, and availability? And breaker size on the 208 panel to feed primary?
Thank you
Thank you
